Go Back   Forum Index > Lancer Owner Forums > Ask A Lancer Owner
Reply
Thread Tools Search this Thread
Old 11-06-2009, 11:52 am   #1  (permalink
Fairwind
-Lancer -28
The Sea Of Cortez
Fairwind's Avatar
Fairwind hasn't generated any comments yet, may be new around here
Lancer 28 Rudder Shaft Bushing..?
Sempre Libra has the stock tiller steering and rudder. The plastic bushing that supports the rudder post in its fiberglass tube has worn to the point the rudder jiggles around a little and is getting noisy. When on autopilot, the small amount of slop makes the machine work harder than it needs to. The original rudder bushing (plastic) has a flange on top that the tiller head rests on. This flange also keeps the bushing from just sliding out the bottom of the rudder tube..
Is there a source for a new drop-in bushing or will this be a custom fabrication job??
Okay, now that it's apart, the "bushing" is actually a length of PVC pipe of unknown size glued in the fiberglass rudder post tube. The rudder post is a heavy-wall stainless tube, 1-5/8" diameter. The flange on top that supports the tiller head fitting is an easy to replace separate part. I will make two bushings (top and bottom) out of 3" wide brass shim stock to compensate for the wear and call it a day..How the brass shims and stainless shaft will get along time will tell..
Fairwind is offline
Reply
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Visit our store at
Lancer-Owners.com...
30% off custom embroidered sportswear
Polos, jackets, sweatshirts... mens, womens, childrens... all with NO minimum, NO setup fees, super-saver prices!
15% off unbreakable engraved drinkware SALE
Bulletproof Lexan drinkware engraved with your boat name. Wine, champagne, beer, tumblers, pitchers, more.
Solar/wind charger
Charge cell phone, MP3 players, cameras, more, without AC or DC power!
15% off butcherblock stove top cutting board
Our butcher block stove top cover is a true work of art! Turn your stove top into useable counter.
Halyard retriever
Don\'t go up the mast! Also works as a handy grapling hook. Sturdy stainless construction.
